Bimmerfest - BMW Forums - View Single Post - Cooling System Overhaul
Old 03-19-2009, 12:20 PM
paferri's Avatar
paferri paferri is offline
Mein Auto: '98 Alpine White E39 528i
This is from autohausz.com.
I am just about ready to order myself. use all the cooling system part #'s minus the power steering, spark plugs, fuel filter, and valve cover gasket stuff as I plan on doing that while I am in there. Also, you may have mechanical tensioner shocks instead of the Hydraulic in my model (2nd and 3rd parts lsted) you need 2 of the 1st pulley listed.....should be free shipping also
Makes
Part Number Brand / Description Price List Core Qty Total
2x 11281748131 Ina/SKF
Accessory Belt Tensioner Pulley/Roller; Alternator and/or AC Belt $16.76 $44.00
11281717210 Ina/Ruville
Accessory Belt Tensioner Shock; For AC Compressor Belt $41.75 $57.45
11281717188 Lemfoerder/Ina
Accessory Belt Tensioner Shock; Water Pump/Alternator Belt; Hydraulic Shock Type $54.20 $84.52
17111712788AFT Aftermarket
Coolant Bleeder Screw; Brass; At Expansion Tank/Radiator; With O-Ring $3.85 $4.95
17111723580 BMW (OE)
Coolant Bleeder Screw; Mounting Clip for Expansion Tank $3.15 $3.30
13541703865 Elaplast/CRP-Contitech
Cooling System Hose Kit; Cylinder Head to Throttle Housing $11.25 $14.82
13541703945 Elaplast/CRP-Contitech
Cooling System Hose Kit; Throttle Housing to Coolant Pipe $3.70 $7.47
17111741167 Behr/OES
Expansion Tank/Coolant Reservoir $60.45 $78.79
17111723117 BMW (OE)
Expansion Tank/Coolant Reservoir; Upper Mounting Clip for Expansion Tank $2.90 $3.40
11521712110 Febi-Bilstein/Meyle
Fan Blade; 450mm; 11 Blades $52.95 $77.33
2100011031 Fichtel-Sachs
Fan Clutch; Screw-On $95.26 $195.71
13321740985 Mahle-Knecht
Fuel Filter; 10 Inch Length with Nipple Fittings $16.81 $34.50
11281738605 Ina/Ruville
Idler Pulley/Roller; Water Pump/Alternator; Offset Mounting $23.80 $43.25
32411097164 ZF
Power Steering Fluid Reservoir; With Filter $17.68 $48.75
32411094306 Cohline/Burgaflex
Power Steering Hose; Cooling Coil to Reservoir $23.15 $32.34
32411093130 Codan
Power Steering Hose; Reservoir to Power Steering Pump $18.45 $30.55
32411093149 Cohline
Power Steering Hose; Steering Rack to Cooling Coil $36.64 $40.38
17111702969 Nissens
Radiator $196.63 $309.52
11531740481 CRP-Contitech/Gates
Radiator Hose; Lower $13.90 $16.30
11531740832 Uro Parts
Radiator Hose; Upper $7.30 $10.97
17111427156 Elaplast
Radiator Hose; Vent Hose from Radiator to Expansion Tank $4.90 $18.35
6PK1560 CRP-Contitech
Serpentine Belt/Ribbed Drive Belt $15.47 $37.30
5PK0906 CRP-Contitech
Serpentine Belt/Ribbed Drive Belt; AC Compressor $9.13 $26.15
6x 12139067831 Bremi
Spark Plug Connector; Coil To Spark Plug; Updated Version 1.8kOhms $5.66 $13.90
6x BKR6EQUP NGK
Spark Plug; 4 Electrode $8.94 $19.45
11531740437 Goetze
Thermostat Gasket/Seal; For Thermostat Housing $0.46 $1.66
11531740478OE BMW (OE)
Thermostat Housing/Water Outlet; Plastic Fiber Material $28.20 $30.29
11531712043 Wahler
Thermostat; 92 Degree C; With Gasket $18.74 $38.50
11129070532 ElringKlinger/VictorReinz
Valve Cover Gasket Set $22.07 $36.46
15x 11121437395 Gloeckler/VictorReinz
Valve Cover Grommet Gasket; Valve Cover Nut Seal $0.93 $1.70
11511722536Z Graf
Water Pump; Update Replacement with Metal Impeller and Gasket $62.90
For international shipping charges please proceed to checkout.
Parts Total $980.76
Refundable Core Deposits* $0.00
Total Before Shipping** $980.76
$744.41 minus the stuff i mentioned above
