Bimmerfest - BMW Forums - View Single Post - DIY: change of the CCV / Pressure regulating valve / oil separator
Old 03-22-2009, 11:57 AM
poolman poolman is offline
Mein Auto: 525i station wagon
Thanks Aioros--I went back a looked at the top of your engine and saw where the connection is made--the metal tube up top. That tube goes to the back of the negine--I suspect that there is another vacuum hose and the other end connecting at the back top right of the intake--you might should check there and make sure those hoses in that area have not given up the ghost --as did the one connected to your ccv valve. I checked mine back there and found them to literally falling apart.
