Bimmerfest - BMW Forums - View Single Post - Rear turn signal not working
Old 04-04-2009, 12:56 PM
SunilPandit SunilPandit is offline
Mein Auto: 2002 X5
Hello BMW experts
I need some help on fixing my 2002 X5 . The rear right turn signal on passenger side is not working. And the turn signal indicator is flashing rapidly . Initially I thought it could be a bulb burn our problem . So I replaced the bulb but that did not fixed the problem. Same Bulb work on the other side turn signal . I also swapped the bulb socket but that did not helped either .
Is there a separate fuse for each turn signal ? If so where can I find ?
What else could be wrong ?
Sincerely appreciate any help.
Sunil
