Bimmerfest - BMW Forums - View Single Post - Rear turn signal not working
Old 04-06-2009, 08:11 AM
Scott ZHP's Avatar
Scott ZHP Scott ZHP is offline
We want the Lion!
Mein Auto: 03 ZHP, 01 X5, 73 MGB
Do a search or read the wiki. This is a common problem on the E53 (X5) and the E46. The metal contact on the cluster is burnt and needs to be cleaned with steel wool and "tinned" with a soldering iron. You can bend the tabs/ears on the bulb carrier, but it is only a temporary fix.
JUST...LOOK...UNDER...THE...CAR....for Chrissakes....it`s like checking to see if a dog is male or female....
Originally Posted by smolck View Post
A bimmer with forced induction should have a proper manual gearbox. Anything less is like french kissing your sister.
