Old 05-03-2009, 01:16 PM
SoonerE39's Avatar
SoonerE39 SoonerE39 is offline
Plays with a stick
Mein Auto: BMW
Great write up and timely for me as I just noticed the grinding noise in the left rear today.
125,000 Miles
However, I found another thread that made me question if the issue could be the swing arm ball joints. (see this thread http://www.bimmerfest.com/forums/sho...=wheel+bearing ). While this thread makes me second guess wheel bearing because the symptoms sound the same, I still tend to believe wheel bearing is my issue.
Does this sound like wheel bearing to you:
metal grinding noise (left rear corner) only when moving
Sound is steady when moving strait, stronger with left turns and non-existant with right turns
I jacked up the lft rear corner and spin the wheel by hand and can clearly hear the grinding and wheel turns with some difficulty.
no squeek/sound when getting in and out.
Agree that this is wheel bearing? I just want to make sure before I throw parts at it.
PLACE SIGNATURE HERE
