Bimmerfest - BMW Forums - View Single Post - Rear Suspension/Wheel Bearing Install...
Old 05-24-2009, 12:10 PM
BosBmw540 BosBmw540 is offline
Mein Auto: 00-540i
Michel,
How did you gain access to the 4 bolts that hold the wheel bearing on the knuckle? Did you take off bearing/hub assembly first or just pull off half way, then you unscrew the 4 bolts?
There is no way for me get access to the 4 bolds before I am trying to pull off the bearing/hub.
Thanks,
John
