Bimmerfest - BMW Forums - View Single Post - 2002 E39 ASC BRAKE ABS lights on => Diagnostic Procedure & Parts Location
Old 06-04-2009, 02:13 PM
Max_VQ Max_VQ is offline
Mein Auto: E39 with a sweet six
Apparently Carsoft can't read OBDII codes but it's supposed to tell me the actual trouble spot but, I guess nobody has the experience to figure out what it is telling us. Sigh. I guess I give up on Carsoft; it turned out to be a total waste of time.
Just a few points:
- On our BMW's OBD is only for emission related systems.
- Carsoft told you the error ABS error code (114) and the version # (Bosch ABS 5)
- I would re-solder any bad solder joint. I can't count the number of things I have fixed just by doing that. You have nothing to loose.
- Here is a list of Bosch 5.7 error codes:
BMW ABS/ASC module - Bosch 5.7
If you experiencing problems with your ABS/ASC and you have Bosch 5.7 electronic you can check the following codes. This Bosch electronic module have problems with engine heat and after some time felts. You can use Carsoft or INPA to check your car.
List of error codes:
5 Right Rear Wheel Speed Sensor
6 Right Front Wheel Speed Sensor
7 Front Left Wheel Speed Sensor
14 Solenoid Valve Relay (check fuses 17 & 33)
15 Pressure Sensor/Pump Error
21 Module Memory Failure - ABS/ASC module is faulty
23 Incorrect Coding - ABS/ASC module is faulty
24 Wrong Impulse
30 Left Rear Wheel Speed Sensor
31 Open Right Rear Wheel Speed Sensor
32 Open Right Front Wheel Speed Sensor
33 Open Left Front Wheel Speed Sensor
50 Right Front Outlet Valve - ABS/ASC module is faulty
51 Left Rear Outlet Valve - ABS/ASC module is faulty
54 Left Front Inlet Valve - ABS/ASC module is faulty
55 ASC Intake Valve - ABS/ASC module is faulty
58 Gear Box Control Unit (CAN bus error)
59 DMER1 (CAN bus error)
61 Steering Angle Sensor Identification
66 Speed Sensor Voltage Supply
67 Intermittent Interference
75 Engine Speed Fault from DME
81 Pressure Sensor
82 Open Yaw Rate Sensor
86 ASC Cut-off Valve Rear Axle
88 Precharge Pump
89 Low Voltage
90 Temporary System Deactivation
94 DDE Fault/Yaw rate sensor
97 Steering Angle Sensor
10 Brake Light Switch
108 SN Control
112 Open CAN to Instrument Cluster
114 Pressure Sensor Offset
117 Brake Light Switch Failure
118 DME Status-Internal Error
I don't know if Bosch 5 codes are different from Bosch 5.7, but I would think they would be the same.
Keep up the good work
