06-19-2009, 09:56 AM
Mein Auto: 1999 328i
Originally Posted by K.I.M.POSSIBLE
Then you need to change your radio to a newer verison and you'll be set. Check Ebay. IT must be a 09/02 or later model radio. Otherwise to solve the cunfusion, many radio's have the wo sets of small terminal in the pbbck. the first set is for the cd changer and the second set is for the Aux cable. Bad thing is that even with the connection in the back, the software that gives you the Aux soft key on the radio controls starts at 09/02 build.
got it, thanks. I'll just wait till I after I overhaul the cooling system and can get the double din adapter to install the deck from my last car (pioneer avic f700bt). I miss having a touch screen gps anyways.
