07-31-2009, 08:45 AM
Search Button Upper Right
Mein Auto: E36 95 325IS Black/Black
Jim you are absolutely right, there is a GREAT thread in this forum about our cars feet; tires/rims, camber/toe, proper inflation, etc etc. I will see if I can't find it...
I remember in that thread it mentioned specs to have your e36 aligned for better control and wear from factory settings. I just found out after the fact
Bilstien PSS9's / SPC Rear Control Arms / DDM Smoked Corners, Sides, Tails / K&N FIPK2 / CXRacing All Aluminum Radiator w Aluminum Shroud and Electric Fan / Stewart Components Waterpump / Aluminum Tstat Housing / SamcoSport Coolant Hoses / Fan Delete Mod - 14" Electric Pull Fan / UBERGROUND Battery Cable / NGK Ir.IX Plugs / Royal Purple Fluids for; Engine, Differential, Transmission, Power Steering.
.  SOLD
MEMBER OF THE MOST EXCLUSIVE SECRET CLUB ON THE 'FEST
