Bimmerfest - BMW Forums - View Single Post - Spark plug DIY at 100k 745i
Old 08-11-2009, 08:04 PM
teejaylentz teejaylentz is offline
Mein Auto: 2002 745i
Originally Posted by rquedog1 View Post
Judd,
In one of the pics posted it says you have to remove the power steering fluid and I guess power steering fluid container; is this true?
No need to remove power steering fluid... The power steering reservoir has two nuts holding it in place. Once removed, you can lift the reservoir upwards (will take a bit of prying to get it over the bolt-ends) and then maneuver it out of the way so that you can get to plugs on the front-left side... You don't need to "remove" it, just let it sit off to the side.
