Old 08-12-2009, 06:01 PM
Judd944 Judd944 is offline
Mein Auto: 03 745i Sport / 01 986S
Originally Posted by teejaylentz View Post
No need to remove power steering fluid... The power steering reservoir has two nuts holding it in place. Once removed, you can lift the reservoir upwards (will take a bit of prying to get it over the bolt-ends) and then maneuver it out of the way so that you can get to plugs on the front-left side... You don't need to "remove" it, just let it sit off to the side.
Correct, you do not need to drain any fluid.
as for the back ones the coil should have plenty of room to be removed on the back ones. is the wiring disconnected?
2003 745i Sport Sterling Gray/Black
2001 986S Seal Gray / Boxster Red
Past:
98 540i Sport
6 944's
