Old 08-16-2009, 07:36 AM
cn90 cn90 is offline
1. FSR: unlikely because you just changed it, but there are people with FSR problem straight out of the box, especially non-dealer part.
Make sure yours is BMW FSR.
2. Blower Motor itself.
Instead of tearing the dash apart just to look at the Blower Motor, study this diagram:
http://www.bimmerfest.com/forums/sho....php?p=3887559
And this diagram:
http://www.bimmerfest.com/forums/showpost.php?p=3203133
On the FSR Connector itself, pins #1 and #5 feed the Blower Motor.
Apply 12 V to #1 and #5 terminals and the Blower should run, if not Blower Motor is bad.
(In BMW terminology 31 is usually ground, 15 is positive feed. So ground goes to SW/GN wire, and positive goes to RT/GN wire).
To be certain that 31 (or terminal 1 on the connector) is ground, using a Digital Volt Meter (a few dollars at Harbor Freight), select Ohm-meter setting, connect terminal 1 on the connector and the chassis, it should read 0 ohm.
Also, check if terminal 2 (Fuse 76 circuit) has 12 V when the HVAC button is switched on.
If you solve this problem, then congrats, you are now formally a BMW master electrician hehe!
HTH.
PS: Make sure you don't have a bad fuse: a bad fuse can either fail completely or fail intermittently. Remove the fuse, check and re-insert it.
