Bimmerfest - BMW Forums - View Single Post - Rear Suspension/Wheel Bearing Install...
Old 08-26-2009, 11:52 AM
cn90 cn90 is offline
Thanks Michel,
So this tool set you mentioned 14-Piece Gear Puller Set is the only tool set we need?
http://www.harborfreight.com/cpi/cta...emnumber=30305
Can you use this tool set to pull the hub-bearing assembly out, then using the same set to remove the INNER race from the Hub?
