Old 10-06-2009, 09:10 AM
romeomike's Avatar
romeomike romeomike is offline
Running life's race...
Mein Auto: 91 318i
Originally Posted by Bimrpwr View Post
try this link...Looks very helpful and has pictures step by step..
http://home.comcast.net/%7Ecdeegan9/...shboard_1.html
For what it's worth, the pictures don't display in "native" Firefox. However, they do show in Internet Explorer, or using a Firefox extension called IE Tab.
Originally Posted by HoffmeisterKink View Post
I did the dash replacement awhile back (http://www.nvo.com/themaus/dashreplacement/). Took some photos of the horror. I spent the good part of a labor day weekend working on it. Taking everything apart was easy, putting everything back together just right is a major PIA that takes time and patience and some muscle. Here's some tips:
1. Do it when the temperature is above 65-degrees F. This will let you bend and flex the pieces into place without worrying about new cracks.
2. Tape and label all the wires. If you have a digital camera, take pictures of everything as you disassemble. That way you can have a reference in case you forget about where something goes while you're putting everything back in.
3. While you have everything out, replace all the little indicator bulbs in your gauge cluster and OBC. Replacements can be bought at Bavarian Autosport.
Good Luck!
I had a question about a recommended temperature setting for this job, and you answered it. Thanks.
On Christ the solid Rock I stand, all other ground is sinking sand. (Edward Mote 1797-1874)
