it can be if you dont know where to pull the trim pieces apart, knowing where the clips are helps. also that headliner can be a pain. the main problem you will encounter will likely be manouvering it out and back into the car. even with the large door openings.
*Der E38*
manufactured: 7/01
color: anthrecite metallic
wheels: style 89 E66, 19X9F 19X10R
ext. lighting: 8000k D2S & LED plate light
*want to get sport rear diff*
