Need help please! 2004 x3 wont start?
ive never had any problems with this car at all. so my battery died from me leaving the lights on. so i jumped it and it started right up. no problem there. so then while the car was running and charging the battery i decided to troubleshoot a problem with the driver side window control switches. i looked into the fuse box and checked a couple fuses related to the windows. i pulled out a 5amp fuse and suddenly the car shut off. so i put the fuse back in because it wasnt blown and now the car wont start. the gas is full, the lights and everything work, the starter cranks while the key is turned but it wont turn over. its as if the fuel pump has been shutoff electronically? any help would be appreciated.
thanks
chris
