11-12-2009, 09:07 PM
Mein Auto: 02 bmw 745i
Originally Posted by teejaylentz
Look inside: http://www.xolmatic.com/xprojects/XE65/M_Logic_7.htm :-)
If this ever happens to me, I'll definitely be taking mine apart and checking the capacitors as a quick possibility. I've found that electrolytic capacitors often go bad and are probably one of the big problems (leaking/tops blowing off). If you are handy with a soldering iron, might be worth a try. When those capacitors blow it's usually readily visible... just have to hope no other damage was done as a result.
Related topic... I've had several PC motherboards fail due to the cheap capacitors blowing. 80% of the time I was able to fix them by just replacing the capacitors. I had some of those surface-mount capacitors go bad in my monitor one time and soldered in some normal ones with same capacitance in their place... been working fine for 2 years...  Here's a pretty good article explaining the capacitor issues that can occur: http://www.pcstats.com/articleview.cfm?articleID=195
I'm not saying this is necessarily your issue, but it's at least worth a look before sinking $1600 in.
EDIT: "Capacitor Plague": http://en.wikipedia.org/wiki/Capacitor_plague
awesome find man... big ups to you.
