Bimmerfest - BMW Forums - View Single Post - How Do You End Up With 22% Alcohol In The Gas Tank?
Old 11-30-2009, 03:42 AM
todd92 todd92 is offline
Mein Auto: 13 X3 3.5, 05 ZHP
Originally Posted by Ryan M View Post
They make the measurement in a graduated cylinder and shake. Then let it sit for a specified time and check the separation against a chart.
No.
Ethanol and gasoline don't separate when you let the mixture sit. If they did there would be a big problem at gas stations. There are a few different lab tests to to determine the ethanol percentage, a dealer would not be equipped to perform any of them. I would stay away from that dealers service department, if possible, they are clueless.
Again, it seems to me you got a bit of water in there. Water can cause the ethanol to separate out from the gasoline. Since you refilled and all is fine, don't worry about it.
