Bimmerfest - BMW Forums - View Single Post - 2009 X5 35D Diesel Exhaust Urea Reservoir Problem
Old 01-17-2010, 09:45 AM
Scot Scot is offline
Mein Auto: a bit of everything
At 2100 miles, as did several of us that posted similar mileages, your dealer likely did not fill up the main reservoir with DEF. If you take it back to the selling dealer, you should indeed point out to them that there are TWO fill necks that they need to put DEF in......the entire system should be approx. 6.5 gallons of DEF. The should not charge you for this.......even though the manual states that DEF isn't covered for 'top off' between oil fills....there is no way that 6.5 gallons would be used during 2100 miles. There are several threads on this between Xoutpost and Bimmerfest.
