Bimmerfest - BMW Forums - View Single Post - E64 645ci 2004 Logic7 Amp replacement
Old 02-08-2010, 06:18 PM
V8HAHA V8HAHA is offline
Mein Auto: M3, 645
Would you mind sending me the pdf also? my email is samtae@gmail.com.
Thanks in advance!
Originally Posted by tampamark View Post
PM me your email address, I can send you instructions in PDF format. The service manual does say that replacement involves programing/coding but doesn't go into any details, you would need to talk with a service adviser about that. I just cannot give you a definitive answer based on the info I have.
Also, I replaced my center speaker with a better speaker. So I have an OEM center speaker that I can send to you for cheap.
Either way, send me your email and I will help. If you want the speaker we can work that out privately.
The center speaker is very easy to change, the grill just pops straight up, I used a thin spatula as a puller tool, just wedged it under and slowly worked ti up around the edges. Once you have it up there are 3 torx screws. it is best to use a torx bit in a rachet since you cannot fit a screwdriver in that space. I can't remember which size torx driver to use, you will need to get a bit set and figure that one out. A set is really cheap.
