Bimmerfest - BMW Forums - View Single Post - the VERY best of E39 Links
Old 02-09-2010, 05:26 AM
- Bentley E39 PDF service manual
- Refinishing headlights/angel eyes
- Radiator weak points & thermostat operation
- QSilver's unlocking the instrument cluster OBC and resetting oil service intervals
- How to tell if you have the high or low OBC instrument cluster
- MID pixel repair here and here and here
- Replacing the cupholders
- Brake pads and rotors price comparison ...
- ABS Diagnostic DIY + P0500 Vehicle Speed Sensor Malfunction + Octane emissions smog test results
- The ingenious fix to the leaky power steering (with the Dexron III fluid all over the cap)
- cn90 parking brake adjustment DIY (and other emergency brake adjustment DIYs) and tons of pictures of a 540i brake job
- OBDII codes specific for BMW
- Diagnosis of intermittent undefined engine stumbling P1349 SES/MIL/CEL OBDII code thrown
- cn90 DIY: 1998 528I Oil Filter Housing Gasket & "Freeze Plugs" Repair
- Spark plug DIY
- -40 ambient outside temperature sensor
- CPS (camshaft position sensor) DIY
- Rear seat center cushion modifications DIY
- CN90 suspension DIY with brake rotor R&R http://www.bimmerfest.com/forums/sho...d.php?t=399580
- CN90 Parking Brake DIY http://www.bimmerfest.com/forums/sho...d.php?t=426640
- CN90 Brake Bleeding DIY using an air compressor http://www.bimmerfest.com/forums/sho...d.php?t=392957
- Adjusting windshield washer spray nozzles and debugging windshield washer spray issues
- Fudman CCV (aka PCV CVV) M54 replacement DIY
- How does the E39 VANOS work
- How does the E39 fuel injection work
- Inspection II part I: Changing your spark plugs
- Inspection II part II: Cleaning MAF & replacing power steering fluid
- Inspection II part III: Water pump, thermostat, belts, hoses, fuel filter
