No for the screen to funtion it needs the nav unit that goes in the trunk. If your car doesn't have that it will be useless. You would have a screen that did nothing. Plus the radio function also would work intermittantly and go off after a few minutes of being turned on. You could however get all the necessary equipment to make it work though. But sounds like what you wanted to do isn't going to work at all. You need to get the same stereo as you already have in there or an updated version, probably the "business" stereo is waht you have.
*Der E38*
manufactured: 7/01
color: anthrecite metallic
wheels: style 89 E66, 19X9F 19X10R
ext. lighting: 8000k D2S & LED plate light
*want to get sport rear diff*
