Old 02-28-2010, 05:31 PM
rmorin49's Avatar
rmorin49 rmorin49 is offline
Mein Auto: 2011 335d
Originally Posted by soberuk View Post
the putty knife will probably work ok but use it to push the silver away from you rather than to prise between the black and silver in case you nick the edges, it will make much more sense when you start doing it than me explaining it. i think right side was from me standing behind the car facing forward so here in england the driver's side was right and for you it will be left. the silver bits are obvious as they have the holes in. the little mesh bits will only fit one way with the wire sticking outwards so they fit around the roll bar screws and into the black roll bar. i am sure it will fine, so good luck with it
To clarify, you were able to grab the silver covers and start to remove them without any tools? What did you grab onto? Seems if you can separate them enough to get your fingers in between the two halves you could pry them apart without using any tools? This would ensure not damaging the black front covers.
Colonel (Ret) US Army / Hagerstown, MD
2010 Z4 s30i Alpine White/Beige
PP/SP/CWP/6MT/CA/NAV/ipod/USB
ED 1-29-10/Redelivery 3-8-10 (weekend car)
2013 Audi A6 Quattro (daily driver)
1985 M635 Euro
2011 335d (Ret)
2009 335i vert (Ret)
2007 335i vert (Ret)
2000 740iL (Ret)
1998 328iC (Ret)
1990 535i (Ret)
1988 635CSi (Ret)
