Bimmerfest - BMW Forums - View Single Post - 03 745Li - Warning lights galore!!
Old 03-09-2010, 08:52 PM
Keif Keif is offline
Master Tinkerer
Mein Auto: 2007 Alpina B7
Beathustler, you might be able to get a copy of your diagnostics report from the dealer from your previous visit...this might be a cheap (free) starting point. Also, I think there may be a board member or two with some diagnostic stuff in ATL there...you may want to try tracking one of them down. Even just being able to pull basic faults (using INPA or something similar) is often very helpful.
Were there any signs of trouble before all this happened? "Recharge battery" warnings? Hesitating / slow cranking when starting the engine? Dim or pulsing lights? Dead flat battery during first cold night?
Black 2007 Alpina B7
Tension strut bushings
White 2007 Alpina B7
Supercharger clutch/bearings, replaced exhaust valve/pulled head, sunroof seal, 6000K angel eyes
Black 2002 BMW 745Li (sold)
KW v3's, blue angel eyes, 8000K headlights & HID fogs, rebuilt alternator & mounting bracket gasket, sunroof seal, CCVs, plugs, sway bar bushings, timing & valve cover gaskets, valve stem seals, guibo joint, mechatronic sealing sleeve, trans fluid, sanded headlights...
