Old 03-23-2010, 09:56 AM
16valex's Avatar
16valex 16valex is offline
Mein Auto: 530I/5SC 97-528/5
Originally Posted by ElwoodBlues View Post
CCV? VCG? Sounds like I've got more searching and reading ahead of me!
CCV is crankcase ventilation or we called it PCV and VCG is valve cover gasket. All M54 I6 engine has a bit of design flaw problem with CCV. The CCV can get partial clog and thus will cause high pressure build up in your crank case causing valve cover gasket and oil filter housing gasket to leak.
