Bimmerfest - BMW Forums - View Single Post - DIY: ATF change GM A5S-390R
Old 03-26-2010, 08:26 PM
Jared@EAC Jared@EAC is offline
Past Sponsor
Mein Auto: 00 540i/6
Originally Posted by Starless View Post
The problem I see here is the same oil conforms to many other specs including Dex 3 and BMW says it's a no-no to mix. Can you really please all with one oil? (Rhetorical question)
That's actually interesting...I did not see those oils before. If they are specifically made to conform only to 8072B, then it sounds better to me than Amsoil fluid...
Yes, you can often please many specs with one oil. Many specs overlap (or are near identical) and as long as there aren't conflicts there is no reason why one can't serve many. You'll see that there are other ATFs on their site also. The one I linked does not meet some of the other specs.
If you search both of those oils you'll see they meet other specs too. It's just not noted on the site. The Fuchs number is TITAN ATF 3353 if you'd like to research it.
