Old 04-20-2010, 12:37 AM
TechGuy TechGuy is offline
Mein Auto: E46 325i
Go in the trunk and take a bit of the rubber (sealant) off on the driver's side. This is so that you can peak through behind the left side trunk cover. At the top right underneath where the c-pillar ends you should have a rectangular silver coloured control unit called the Telecommunication Unit or TCU. And on it there will be a sticker which has a 4 digit number printed. That 4 digit code will be your pairing code.
