Bimmerfest - BMW Forums - View Single Post - E39 speed sensor / abs issues!! help!
Old 04-20-2010, 08:22 PM
Jared@EAC Jared@EAC is offline
Past Sponsor
Mein Auto: 00 540i/6
Originally Posted by Ironnerd View Post
Gents - this info is very helpful...I have the DSC light on with airbag and an intermittent check engine. Code for check engine says camshaft position sensor - yet no starting problems. Replaced front camshaft sensor - no change. Can't seem to find any other codes - was thinking I would try replacing the DSC and ABS relays to see what happens...anybody tried that before replacing the module? Thanks!
The camshaft sensor code is probably not related to your DSC light. What CPS do your codes point to? You replaced just one sensor, your other one may be bad.
