Old 04-23-2010, 09:18 AM
Keif Keif is offline
Master Tinkerer
Mein Auto: 2007 Alpina B7
And, larsizzle, since you have the pre-facelift 745, you don't have to loosen the bumper or anything, just unbolt the headlight assembly and move it forward a little.
Black 2007 Alpina B7
Tension strut bushings
White 2007 Alpina B7
Supercharger clutch/bearings, replaced exhaust valve/pulled head, sunroof seal, 6000K angel eyes
Black 2002 BMW 745Li (sold)
KW v3's, blue angel eyes, 8000K headlights & HID fogs, rebuilt alternator & mounting bracket gasket, sunroof seal, CCVs, plugs, sway bar bushings, timing & valve cover gaskets, valve stem seals, guibo joint, mechatronic sealing sleeve, trans fluid, sanded headlights...
