05-06-2010, 02:21 PM
Still Cruisin'
Mein Auto: 2003 325xi, 2001 Z3 3.0
Originally Posted by Gotechslack
Good info. Thanks. So, you think it is a good time to do this? Of course I read that my manual tranny may have the lifetime fluid in it and not to bother changing it (I don't buy that). Is the Redline products you indicated, synthetic? I assume a synthetic fluid type is in there currently? I may try to look for an independent on this one. If I don't have any luck, I'll try it myself. I do have some jack stands; they are just not very "big." I guess they would still work if I placed them under and on the jack access points, huh? I do have a level garage. Thanks again.
Well, actually, if you followed the old school BMW maintenance schedule when they actually maintained cars, you would have done it at 1200 miles, then every 30k.
So yes, I think you should do it today, if you can.
I wouldn't climb beneath the car unless each of your jackstands has a 3000 pound capacity. I myself use 6k pound jackstands. Your life is worth more than what it costs to buy good stands.
Red Line products are all synthetic, yes. I would bet you notice an immediate improvement in your shifting when you change the fluids.
If you don't have time, find a good indie, and use good synthetics. I believe in Red Line, but Royal Purple makes good stuff too.
