I wouldn't be too worried about it. No e36 will have original suspension components at this point and in many cases aftermarket is just as good, or better, then stock. It does appear to have front camber plates, you just want to inspect both front and rear shock towers and check for cracks or damage. With those wheels, stock brakes, OEM radiator... I doubt it was seriously tracked. Suspension is probably just for stance. I would put it around $8000 to $8500 if it checks out with a paint meter and all the VIN tags on the body panel match.
