Old 06-05-2010, 09:14 AM
Hooray!'s Avatar
Hooray! Hooray! is offline
Mein Auto: 2002 530i Sport Premium
Originally Posted by Johnny Canada View Post
I purchased a roll of Butyl adhesive (that's what the factory uses) from a local auto body supply company. It sticks like crazy on the door, but I had issues getting a secure bond on some smaller areas of the vapor barrier. I think that the process of removing the barrier, and the old Butyl, slightly delaminated the surface of the barrier. If I ever need to do this again, I'll order new vapor barriers (about $35 each) to insure clean bonding surface.
PS: A quick way to check your vapor barrier is to remove the Puddle Light and stick your finger inside. The panel will be wet in that location if the barrier is leaking.
For $35@ probably not a bad idea, do it once, do it right, never do it again. I'm thinking of picking up the BSW stage 1 speaker upgrade kit as well and swap out the stereo speakers at the same time... again, dont want to open up the door again while I have the car (the PO replaced both rear window regulators, hence why I suspect they leak).
2002 530i
Exterior: Black
Interior: Black
Packages: Sport, Premium, Cold Weather
Options: HID, Folding Rear Seats, Ski-pass
