Bimmerfest - BMW Forums - View Single Post - E38 Transmission Fluid Change.
Old 07-11-2010, 04:51 PM
e38cruiser e38cruiser is offline
Mein Auto: E38 1995
Meteck
Originally Posted by meteck View Post
OK, so mine has 73000 miles and shift hard the first time when cold. Otherwise works perfect and I have put 3000 miles on it in the last 2 wks. Already have change kit and plan to change it as soon as I can it it still long enough.
95-99 e38's need to warm up! Temp needle almost out of the blue and the car shifts fine there is nothing wrong with your car. I forget what the switch is called but it is supposed to do that at start up.
DO change fluid and filter with the right stuff and feel the differance the car even idols better. Also if you have a mesh strainer on your power steering reservoir you need to change the filter at the bottom of this reservior and fluid
