Bimmerfest - BMW Forums - View Single Post - E38 front right turn signal assembly a DIY job?
Old 08-20-2010, 02:01 PM
M.Wong's Avatar
M.Wong M.Wong is offline
E38 E91 (R56 E30 E39)
Mein Auto: The E38
Open the hood and look for a small plastic cap over a hole in the lip that looks like a 'rain gutter.' Remove the cap and use a Phillips screwdriver to loosen (not remove) the screw that's down in the hole. It's a clamp, so you only have to loosen it.
Slide the corner turn signal forward, unplug, swap.
(Photos from e38.org)
M.Wong
E38 2000 740iL Orient Blue
E91 2012 328xiT Alpine White
Passed on to new families:
E30 1987 325i Royal Blue
E39 2003 540i/6 Sterling Gray
R56 2010 Mini Cooper S British Racing Green
