Old 08-21-2010, 01:46 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
Originally Posted by IgotBMW View Post
drivinfaster, I may take a crack at DIY on this.
Do you know if I will need a Crankshaft puller to pull the Crankshaft Pulley off?
no, it is bolted to the snout hub. undo the bolts that hold it to the hub, and then undo the crank bolt. the hub should slide off the crank snout with the crank bolt removed.
did you get a new crank bolt?? they're not supposed to be reused per bmw.
df
