Old 09-12-2010, 10:26 AM
To continue with the lessons learned, apparently 1.5mm is too thin.
(For comparison, mine are 3/8ths inch thick.)
"Fudman fabricated his own using the dims posted here on a thread, it was 1.5mm thick stamped steel (pretty light duty), the 2nd revision started life as the hardened steel bar stock from a garage door opener (that part with all the holes drilled in it that the door quick disconnect attaches to), it was much closer to the 4mm thickness of those "beautiful" tools in your photo (need me some of those), have you used them yet for your cooling system or VANOS? ... and yes geezer, us east coast nuts are VERY hard to crack and on the equipment!"
