Old 09-20-2010, 07:21 AM
doru's Avatar
doru doru is offline
Mein Auto: 2003 530iA
Thanks Seth for the wonderful update for the VANOS seals parts list.
For me, (and maybe others), the BIGGEST hurdle is figuring out which parts to buy, which tools to get, and what else to do (while you're at it).
I've updated the recommended parts list with all your information.
Thanks!
I would bump these: 15 valve cover bolt grommet in the "Highly recommended" section.
There is no point buttuning up the new VCG with old, hard grommets - you will have oil leaks very soon.
Also, just because you will loose some coolant, when topping back up once the job is done, you might unscrew the bleed valve on the upper radiator hose. That plastic bleed valve, can desintegrate - I know it did on me when I changed the vanos. Have a new one ready as a "highly recommended" part, or even better the brass one.
0.02
