Bimmerfest - BMW Forums - View Single Post - K1300GT Final Drive Oil Change
Old 10-09-2010, 05:12 AM
KarlB KarlB is offline
Mein Auto: 11 335d,08 K12GT,10 S1000
still didnt get my issue but can say you can pull the rear wheel without taking exhaust et al off-- pull one bolt and shove the slip on to the outside of its brackets and you have clearance to remove the rear wheel, caliper should be 2 bolts so a little more of a pain in the arse than an air/oilhead or even K1200RS (done fd changes on all of them) not a big deal but tming it with a rear tire change would be easy since the new K bikes go thru them lke tic tacs--- I only get 3-4k miles out of rear tires--- but those are oh so fun miles!!!
I def wish when they go to "lifetime fills" they would still make allowances for those that "want" to change the fluid
11 335d
2010 S1000RR
08 K1200GT
08 WR250R
