Old 10-29-2010, 09:05 AM
Keif Keif is offline
Master Tinkerer
Mein Auto: 2007 Alpina B7
How much you have to do depends largely on what version you are running. Most of the v44 images have been boxed up pretty well and you won't have to do much, but there are a few things. Within DIS, check out the ediabas.ini settings, the network card settings, and stuff like that. Also, are you running the diaghead emulator? Have you made the proper modifications to ediabas.ini on the INPA side? There should be step by step instructions out there for setting up all this stuff, but those are some of the things you'll likely be poking around in. Assuming you're running DIS in a VM, make sure you have a virtual network set up in VMware using the proper .30 or .68 subnet (I can't recall off the top of my head which it is, but you'll find it in the steps).
Black 2007 Alpina B7
Tension strut bushings
White 2007 Alpina B7
Supercharger clutch/bearings, replaced exhaust valve/pulled head, sunroof seal, 6000K angel eyes
Black 2002 BMW 745Li (sold)
KW v3's, blue angel eyes, 8000K headlights & HID fogs, rebuilt alternator & mounting bracket gasket, sunroof seal, CCVs, plugs, sway bar bushings, timing & valve cover gaskets, valve stem seals, guibo joint, mechatronic sealing sleeve, trans fluid, sanded headlights...
