Old 11-06-2010, 09:59 AM
JayMac JayMac is offline
Mein Auto: 1997 328is
Just an update on what my noise was. We are upgrading the entire rear suspension. Found a bad outer cv on the left side. The noise was coming from the lower ball joint bolt. Number 10 in this diagram:
http://www.realoem.com/bmw/showparts...04&hg=33&fg=30 If I have this correct the 328 has a bushing but you can upgrade to the ball joint used on the M3. Since this car will be tracked by all of us in the family we opted for the kit from Turner and reinforcement plates all around. More than I wanted to spend but piece of mind is priceless when you hit the power in the corners.
