Bimmerfest - BMW Forums - View Single Post - HELP PLEASE Reset Z3 oil service light
Old 11-10-2010, 01:04 AM
z3-o1 z3-o1 is offline
Mein Auto: bmw z3 1997 1.9l Auto
Originally Posted by rtsuggs View Post
How did you do it?
Simple
Turn the ignition switch to position two (2). Connect the clip end of the jumper tool to a good ground in the area of the data link connector. Connect the pin end of the jumper tool to pin seven (7) of the data link connector and remove it after the appropriate time, depending on which reset you are doing. Replace the data link connector cap and turn off the ignition switch. Check to see if the reset worked by starting the car and seeing if the lights go out. If they do, good job!"
10 secs should do it let me know how you get on
ID:	254013   Click image for larger version
