Old 11-19-2010, 02:46 PM
Keif Keif is online now
Master Tinkerer
Mein Auto: 2007 Alpina B7
Originally Posted by Khabar View Post
What is the name for rear joint? How are screws? Are they to rusty to removed with hand tools? The center mount dose it has to be relaxed whole or only ring in the middle?
The rear joint is the constant velocity (CV) joint. Everything should be able to be removed with hand tools.
Originally Posted by MOPAULY View Post
I would like to do this tomorrow - Keif do you have the torque specs for the guibo bolts?
See attached file.
White 2007 Alpina B7
Supercharger clutch/bearings (check DIY), sunroof seal, quarterto8's 6000K angel eyes, bumper side mounts
Black 2002 BMW E66 / 745Li (sold)
KW v3's, blue angel eyes, 8000K headlights & HID fogs, rebuilt alternator, sunroof seal, CCVs, NGK Laser Platinum plugs, sway bar bushings, battery, timing & valve cover gaskets, valve stem seals, guibo joint, mechatronic sealing sleeve, trans fluid, alternator bracket mounting gasket, sanded headlights...
