Old 11-23-2010, 09:11 PM
energizedmortal's Avatar
energizedmortal energizedmortal is online now
Mein Auto: 2003 530i
Originally Posted by Fudman View Post
Are you sure it is from the drain plug? Maybe the oil filter housing gasket?
thanks for the suggestion upon further inspection oil is weeping down from driver side and across pan and falling off drain plug. once i confirm its the oil housing and/or gasket i will be using your ccv DIY to do that while im there
