Bimmerfest - BMW Forums - View Single Post - Stupid question. e34 95 540 i atf/power steering fluid
Old 12-20-2010, 03:24 PM
remy0213's Avatar
remy0213 remy0213 is offline
Mein Auto: 95 540 I
Originally Posted by zaleonardz View Post
Howdy,
Pentosin CHF 11S is what your after there, ATF is also fine.
I have had excellent results with Shell Donax TX, incidently this Donax TX can also be used on the 540's transmission (5HP30) with stunning results, and the stuff is dirt cheap. If your considering buying, buy a 20 litre and flush your gearbox as well, here its about R50 for a litre, so thats really not a lot of money.
Also, here is a scary fact, your power steering fluid is actually shared with the booster side of your braking system, called the H31 braking system.
If you are loosing fluid, it may be at the brake booster, its a very common place to leak from.
If your standing in front of your engine, on the back in the right hand side, you will see the master cylinder attached to another long cylinder, thats your brake master. Where the brake master and brake booster meets, (a little triangle), right there is where it leaks from, time and time again.
Give me a pm if you need any more information on this one.....
Okdokie then for the atf, tomorrow i will purchase this. Im not quite sure if anything is leaking as of yet. IT was burning one day but im not sure if all the caps were tight after people probing around.It was 2 times and hasnt been, so i dont see no wetness around anything this morning. Ill know more tomorrow. Took a break but thanks...
