Old 01-06-2011, 05:08 AM
cn90 cn90 is offline
Mein Auto: 1998 528i 5-sp 103K miles
Originally Posted by Ebonix View Post
Thank you, and believe me, it is easy, i even impressed myself as well as the kids, i just used common sense, no books, no repair manuals etc, basically i got under the car and relied on memory as to how things were put back together, the hardest part was jacking up and stabilising the car lol. If i had the part at the time it would have taken a good 4 - 5hrs in total. This repair was done over a 3 day period.
To have inline images there must be a special feature then?
Couple things:
1. Did you preload the center bearing?
2. To insert image at step-by-step:
- Right click on the image you want and "Copy Image URL". For example you will see the 1st image as:
http://www.bimmerfest.com/forums/att...1&d=1294299314
- Then place the cursor where you want the image to be, hit the icon "Insert Image", then Paste the URL. You can leave the whole URL alone or shorten it to the picture id as below, the software of the forum only cares about attachmentid=261169, and not the strings of letters/numbers afterward:
http://www.bimmerfest.com/forums/att...hmentid=261169
Go back to your message and edit it and you will see, it is very easy to do this step-by-step picture thing. In fact much easier than replacing the Giubo!
