Thread: DISA 0 Ring
Old 01-17-2011, 11:29 AM
Originally Posted by pleiades View Post
Is the DISA Valve O-ring unavailable for M54 engines or no longer available in general?
It looks like there is no part number for the M54 engine in Realoem.
But that doesn't mean there isn't a similar part that BMW sells that we just don't know the cross reference to.
For example, the #4 o-ring below is an exact replacement for the lower radiator hose thermoswitch o-ring (which itself doesn't have a part number).
Maybe we can find a similar o-ring in the BMW catalogue for this DISA valve (aka #7 Adjuster Unit).
Does anyone know the size of this DISA Adjuster Valve o-ring?
Here is the link on realoem for my M54 engine.
Realoem clearly lists two different o-rings:
# Description Supplement Qty From Up To Part Number Price Notes
04 O-ring 8X3 1 13621743299 $1.25
06 O-ring 7X3 6 11617502761 $0.88
But neither o-ring is for the DISA valve, per se:
07 Adjuster unit 1 11617544806 $212.50
Here is the complete listing from Realoem.
No.DescriptionSupplementQty From Up To Part NumberPriceNotes
01INTAKE MANIFOLD
1
09/200211617502268
+core, ENDED
01INTAKE MANIFOLD
1
11617525752$615.48
02Set of profile gaskets
1
11611436631$63.30
03Temperature sensor air
1
13621739510$25.98
04O-ring8X31
13621743299$1.25
05DISTRIBUTION PIECE
1
11611440318$58.23
06O-ring7X36
11617502761$0.88
07Adjuster unit
1
04/200411617502269
+core, ENDED
07Adjuster unit
1
11617544806$212.50
08T-SHAPE IDLE REGULATING VALVEBOSCH1
13411744713$211.28
09BRACKET IDLE ADJUSTER
1
11617502271$14.98
10Rubber grommet
1
11611437453$20.65
11Rubber Mounting
1
11611432564$7.60
12Torx-bolt with washerM6X184
11611440384$1.12
13Oval head screw
4
07/200611611705032
ENDED
13ScrewK60X224
11617533331$0.75
14Hex nut with plateAM79
07129902630
ENDED
15CapD=3,5MM2
11611437560$3.39
16Cap nutM61
12421438388$0.63
17CapD=7,0MM1
11611727176$3.39
