Bimmerfest - BMW Forums - View Single Post - O2 Sensor Question
Old 01-27-2011, 08:51 AM
oembimmerparts oembimmerparts is offline
Mein Auto: 2001 Z3
Originally Posted by Chisum View Post
I bought a 2003 525i with 54k last month and have been getting the parts together to fix all the little things that need work. I ordered a Peak scanner and got it last night. I cleared all the codes and this morning when I took my wife to work the SEL came on with 2 codes
E3 O2 sensor adaptation limit Cyl #1-3
E4 O2 sensor adaptation limit Cyl #4-6
I cleared them and drove to work about 12 miles with no codes.
With only 54k is it likely the O2 sensors are failing or that I have a vacuum leak or could it be something else?
Chisum
The pre cat O2 sensors seem to be the only ones that fail compared to the rears, Your mileage is pretty low for that but O2 senors are working as long as the engine is running so if the car is always in traffic it may have low miles but higher use on the o2's
Max
