Old 01-30-2011, 07:25 AM
goosefoot33's Avatar
goosefoot33 goosefoot33 is offline
Manualaholic
Mein Auto: 01 330Ci/02 525iT
Check Pelicanparts, Autohausaz, Bavauto for coil packs. There are also several vendors that endorse this site that you can try looking into. When I replaced my spark plugs, I went with NGK. Once you enter year year and model on Pelicanparts or Autohausaz it will give you only plugs that will fit your car. Check out ebay for used coil packs too, sometimes people are selling stock ones after an upgrade.
I would run some Lucas fuel and injector cleaner through the system as opposed to the Seafoam. I have used Lucas and Chevron Techron before and I like Lucas just a little bit better. This may not solve the issue though- when my 5er starting throwing a misfire code, I ended up pulling the fuel rail and you couldn't even recognize the injectors from underneath all the carbon that was built up in it. I hope it's not too bad for you
BMWCCA Member# 451235
(Summer) 2001 330Ci - ZSP
(Winter) 1994 530i "Greenie" - PARTING OUT! (PM for details)
(Grocery Getter) 2002 525iT
