Bimmerfest - BMW Forums - View Single Post - What years of X5's are most susceptible to the dreaded oil separator failure?
Old 02-02-2011, 06:45 AM
HPIA4v2 HPIA4v2 is offline
Mein Auto: E60, E71, E92
Originally Posted by BethL View Post
I just checked my last invoice from BMW (I've had the oil separator issue for YEARS). They installed a 'heater grid for the oil separator.' Hope that helps. Unfortunately, that's all it said, so if it has a technical name, it didn't show it. Also, the manager at Motorwerks actually told me - 'don't expect that to work.' So, there you go.
For that heater to work, it needs to be on about an hour or two before you start the engine/driving off, after parking on the open lot at work/mall/grocery store etc when temp is below zero for example.
It can't stay on all the time when engine is off or your battery will be dead.
Now if it's only on when you start the engine and you have frozen water/oil (oil always have some water in it) already, it won't do you any good cause the crank-case presure build right away.
