Since this is an old thread but about the same subject, I will post 3 questions :
Have someone used the Meistersatz tranny filter? Had any problems with it? I've read that aftermarket filters can cause whining ...
When you change the tranny oil, do you let the car idling without the drain plug on? To flush out the converter... Doesn't damage the clutches?
About how many qt. of oil you were able to pull out? I know that the capacity is 9 qt with the torque converter.
THX. in advance!
